Hi all,
I've recently built the below:
Gigabyte Aorus B450 Pro
Ryzen 2600 stock cooler
Gigabyte GP-B700H700W PSU
MSI GeForce GTX 1660Ti Gaming X 6144MB
Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-24000C15 3000MHz
WD Blue 3D NAND 500GB 2.5" SATA 6Gbps Solid State Drive
Zalman i3 Edge Midi-Tower Case
I just done a stress test out of interest and noticed my CPU temp running high to the point where I stopped the test after only a few minutes, weirdly if I remove the side off the case, the temps drop to 69c max. Currently idling at 36c. The moment I do the stress test, with the side panel on, the temps rocket to 85c after about a 10 minute stress test. I then get scared and stop the test!
Is this normal? No overclocking all running stock.
