Well, yeahMikol said:I use it at 720p on my monitor and it's so much better than 576i or even 480P!
monkeyspank said:Well, yeah
When it's upscaling DVDs it does a reasonable job but my standard def £60 DVD player looks better.
Lanz said:Instead of buying the official High Def pack for the xbox, I bought a Gamestar one:
Im just checking to make sure this will work fine, as it was much cheaper than any official one.
cheers
Mr Latte said:Complete utter disaster, of course i speak from experience.
1) The offical MS HD pack with PAL-NTSC softmod (non hardware mod)
2) The Neoya HD-VGA cable
Lanz said:So what are you saying? This component set of leads wont work?
Im not paying 70 quid for an x2vga box, the VGA/DVI port will have my MCE plugged into it anyway.
What im saying is i had this device and im almost certain it just outputs RGB over the component cables.
