AC use a different mixture than most other companies (Mayhems, EK, etc) and their devices are designed around that. So their product manuals do generally state (where applicable) that correct calibration requires (among other steps) that you should use their Double Protect Ultra™... However, their techies have also said you can use distilled water mixed with (IIRC) up to 30% glycol additive... whereas I believe Mayhems et al are closer to 40% glycol, so too viscous to work with their kit.It would seem the water quality measurement only works with their own liquids so beware.
Did you guys get yours from the shop of the same name as the product? Did you have to pre order? Did they take long to come? I signed up for notifications and one came through, but was already sold out when I clicked through.
Yeah, that’s where mine is coming from. Should be delivered today. I was just checking the website every few days, and noticed the stock level had a green dot, so ordered there and then, didn’t pre order it. It must have been the last unit they had, as they were out of stock after I made my purchase.
With regard to water quality, in my first test I used distilled water and within a relatively short time the quality fell from 100% to 50%. But then I added EK Cryofuel concentrate and it went straight back to 100% and stayed there.
I would imagine it’s measuring conductivity of the liquid.Interesting. Do we know exactly what it's measuring?
After this, no more spending on my loop, I've promised myself![]()
Hahahahahaha like that's going to happen there is always something that takes your fancy! I was happy with the Nickel fittings in my loop now I'm on a tube bending mission to eradicate them! For four and a half years I thought they looked the mutts now I want them gone!
I was happy with my Parvum case....No that had to go.
I was happy with Titan X(Pascal) SLi no had to go!
I Guess the I7 6950x days are numbered!
