I recently partook in a new watercooling loop after many years away from watercooling. I picked up a v8 bundle from OcUK here, with the HL black ice rad, and some Mayhems pastel fluid.
Now, its been many years since I did my last loop (I was cooling a socket A AMD chip, so yes, its been a while!) so I am not totally foreign to the principles and how-to on settings up a loop, but this problem is really bizarre.
The loop is installed, with flow going...
Pump/Res -> CPU -> Rad -> pump/res
nothing too exotic there. I did the usual leak testing, but this is where things have changed a bit. In the dim and distant past, I assembled my loop outside of the chassis, and ran it off the PSU for x hours for leak testing. The advantage of this being that you could really shift the Rad and blocks about to get all the air out. Problem is, with this new kit, that ain't possible, so I followed the instructions and installed, primed and bled it in the chassis. Did I get all the air out? I think I did, but its hard to say.
Anyway, onto the problem. It's all running now, great. Idle temps are slightly lower than they were with my K2 Mount DOOOOM (about 30 degrees now), but the load temperatures are off the scale. I have seen 3 of my cores hit 105 degrees, which I believe is the max temp for this CPU (which incidentally is an Intel i5-3570k running at 4.4 ghz on 1.32v). I should add that for reasons I have never understood, core 1 always sits about 20 degrees cooler than the others. Did on the air cooler and does on the water block. I will also add that on air, the temp would only get to 80-90 degrees on heavy load (prime).
So, what have I done to try and sole this puzzle? Well, here you go...
1). Re-seated the CPU block.
2). Checked (best I can) for air in the Rad. Don't think there is any in there.
3). Lowered the OC on the CPU to 4 ghz, but the temps are still shooting up to the max as soon as the CPU is stressed.
4). Checked the loop for any kinks etc. and there are none.
Now, to my knowledge, it would seem that the pressure/flow through the block isn't high enough, as the coolant isn't shifting the temperature away from the block fast enough. However, this is a simple loop with a reasonable pump/res combo (XSPC 750), so I can't see how it would be that. I have got the flow going the correct way through the block before you ask.
Too much thermal paste maybe? I did clean off the old stuff (AS5 i believe it was) and used the XSPC paste instead. Could too much of that cause this issue?
So, I put it to you, can anyone think of any reason why the loop would be doing this?
Thanks in advance!
Thanks in advance!
