Hey guys! I just picked up a GTX 660 really cheap, and I've compared the frames that other people get to what I get, and I seem to get a lot less then everyone else, even though my PC is about the same in power. I decided to run Firestrike, and weirdly enough I got better score than the average, but my frame is still kinda low. I mainly play wow and CS GO, and the weird thing in wow is that the frame seem to change a lot depending on the camera angle, as show in the pictures here: http://imgur.com/a/Dr4sU this doesn't really feel normal, hopefully you guys can help out! My other specs are a i5 [email protected], 8GB of RAM, and a Asrock z77 PRO4-M. I should also add that the gpu load is 100% when playing
I get like 30-40 fps when on high on BF3, and I can barely keep 60fps on wow with Good settings (medium more or less), as I showed in the picture however, the fps changes A LOT when I look in different directions, which I don't think should happen
