What do the core temps look like for the gpu? It is fairly old. Could be throttling due to the paste going bad.
It's around 45-55 during 100% load, I got pretty good cooling in my pc
I have pretty low settings already, tried it with mainly low settings and I can barely keep 60 in combat alone, but when I go inside etc it raises to like 400 fps... Same with cs, can be at 250+ normally, but as soon as there is a lot of shooting/frags, it can drop to sub 50, and I have the lowest settings on 1280x960WoW also has SSAA now, which is even more demanding. You can drastically improve performance by dropping a few key settings a notch or two. Drop shadows to High, SSAO to Low, liquid detail to High and AA to CMAA and you should see a drastic improvement. You can also drop some other settings like sunshafts, depth effects and view distance a notch without any real visual impact to help performance a bit more.
I ran it on a GTX 570 for a while last year whilst between cards, which is around the same performance as a GTX 660, and got a pretty steady 60fps with those settings. Even in Trashran.
MMO's are heavily cpu bound not gpu! I play Guild Wars 2 trust me its the amount of players on screen that kill fps and it is not relative to your video card at all.
I am/was overclocked to 4.8ghz on a 3770k and a gtx 980 and in big zerg fights my fps will just drop down just as you mentioned
I know that, but the problem is that I have a problem keeping 60fps in normal 1v1 combat on lowest settings!
Sounds like a game issue then. Have you tried clearing your WTF folder and removing some addons?
All lowering the graphics settings is going to do is make the game rely on your CPU even more compared to GPU.
I know for a fact that Recount is an FPS killer, so much so for Mythic raids the entire guild swapped to Details.
I don't think it's specific to the game, I can't even get past 50 frames on FC3 with lowest settings on 1920x1080.. The thing is that I get high scores with the card in Futuremark though..
