Just got hold of a D-Link 624 router as a replacement to the Home Hub.
Got a rock solid connection now with no line drops but only connected at 576kbps (IP Profile set at :500)
My SNR Margin is very high - up and down is both 30, with Line Attenuation at 31/47.
Any ideas how I can reduce the SNR Margin which would increase speed?
Or does the ISP have to set the SNR Margin? If so, will they adjust it automatically ( I, for my sins, are with BT
Thanks
Thanks
