if I read it correctly - per the LG documentation @4K /60fps the 4:4:4 deep color chroma sampling only works on the hdmi input at 8 bits (not 10 or 12) , which is consistant with earlier statement of hdmi 2.0 capability.
Indeed.
HDMI 2.0 does not have the bandwidth for 10bit 4k@60hz with 4:4:4 chroma
Stupid question - You followed these instructions?
The X700D can display Chroma 4:4:4 at 4k @ 60Hz only on the HDMI port 2 and 3 and you need to switch the 'HDMI signal format' to 'Enhanced format'. When the picture mode is set to 'Graphics' or 'Game' the input lag is 31.4ms.
It can't be the GPU either, I have a Titan X SLI (Maxwell 2) which is essentially the same GPU as you are using and 4k@60hz with 4:4:4 is working fine for me on my Panasonic AX802B
As soon a game is launched display goes blank. So TV itself is not the problem.
You said
you mean you were sending same format from the PC and that was successfully showing a picture on tv, up to the point you started the game ?
I have seen some cable problems that are content specific - cross-talk/degradation that occur only with some content.
Maybe the Sony hdmi connection phis/io's have less electrical tolerance than the 4K monitor to signal degradation
were other successful folks using same 5m length - have you tried shorter ?
Tried 2m, 4.5m and 5m. All cables do 4K 30hz 4:4:4. 4K 60hz 420 only.how long are the cables?
does it work with std 4k 60 hz?
OK : have you tried playing a 4k/60fps video on the desktop to monitor, and will that then fail to display.
Can audio interleaved with the video across hdmi, ever impact video integrity causing a loss of display (so try changing audio format) or does game enforce an hdcp2.2. handshake that is not required with desktop.
Spanner in the works from tv specs (could be barking up the wrong tree)
Panel Refresh Rate : 50Hz
it may support 3840 x 2160/60p but is the gpu outputing 60p?
can you set the output to 50 Hz (cru utility possibly)?
Virus, I think you are confusing the 'YCbCr 444' setting on the Nvidia control panel with 4:4:4 chroma on the actual TV, they are two different things.
To enable Chroma 4:4:4 support on an LG OLED, first go in the 'General' menu, then enable 'HDMI ULTRA Deep Color' for the HDMI port that you are using. After, change the input icon to PC in the 'All inputs' menu, accessible thru the remote input button.
