The above are my idle temps. Bit high yes? 20C higher than they should be? At full load they reach 70C. I have even lapped the CPU and heatsink (Noctua NH-U12F with Sharkoon 1000), which gave a 5C decrease in idle temps. I use Arctic Silver 5. My room temperature is 21C.
I have one Sharkoon 2000 120mm for inflow and two 80mm fans for outflow. My 8800GTX blocks air flow from between it and the HDD racks, but theres still an adequate gap between the 8800 and side panel. My case is the Coolermaster Praetorian by the way (my front panel is open).
So any ideas?
I just reapplied thermal paste thinking I didn't put on enough last time, but the temps are actually higher now.
