Hi all, starting a new job, which has ment moving I have no space for my desktop pc, which I was planning on upgrading next year, so having to bite the bulit and spend the money now and get a laptop. What I am really looking for is something that can do the work of a desktop, will mostly be used or games, dvds and internet, but be compact have looked at some of the 19" laptops but think they will be do big, if I am haveing to use my bed or lap for the majority of use. I have a budget of £3000, I have done a bit of research and have found the following 4 options, looking for a bit of advice, value for money, bad experiances, good experiances or other suggestions.
many thanks
Mark
Option 1: Xtreme CTX = £2234.85
Intel Core Duo T2700 2.33GHz / NVIDIA Quadro FX Go 2500M 512MB (CAD/3D design) / Hi-res WUXGA+ X-Glass no rock logo / 2GB DDR2 667MHz (1GB x 2) / 100GB 7200rpm SATA / 8x +/- Dual Layer DVD Writer
Option 2: Znote 6214W = £1239.26
Intel Core Duo T2700 2.33GHz / nVidia Geforce Go 7600 512MB / 14" WXGA Crystal Clear 1280x768 / 2048MB (2x1024) DDR2 PC5300 - 667MHZ / 100GB 7200rpm SATA / DVD-RW Dual Layer Slot-in
Option 3: XPS M1710 = £2369
Intel® Core™ Duo Processor T2700 (2.33 GHz 2MB L2 cache, 667 MHz FSB) / 512MB DDR3 nVidia® GeForce™ Go 7900 GTX / 17" UltraSharp™ Wide Screen WUXGA (1920x1200) TFT Display with TrueLife™ / 2048MB 667MHz Dual Channel DDR2 SDRAM (2x1024) / 120GB (5,400rpm) / 8X DVD+/-RW Drive Double Layer
Option 4: Aurora m9700 = £2359.40
AMD Turion™ 64 Mobile ML44 2.4GHz 800MHz FSB 1MB L2 Cache / Dual 256MB NVidia® GeForce™ Go 7900 GS - SLI Enabled / High-Definition Audio with surround sound / 17" WideUXGA 1920 x 1200 LCD with Clearview Technology - Saucer Silver / 2GB DDR SO-DIMM at 400MHz - 2x1024MB / 160GB (80GB x 2) 7200 RPM SATA / 8x Dual Layer DVD+/-RW / 24x CD-RW Combo
many thanks
Mark
