Higher idle Temps?
25 Nov 2011
The KOP
Guys think I have found out why I been getting higher Idle temps then before.
Couple of us have noticed changing from 14.4 drivers we got high idle temps and was fast to blame 14.6.
Well I have done some testing and went back to 14.4 and noticed idle temps was the same about 40-45c, when I remember I used to get 35-40c
So I started looking at other things I have changed, started closing down programs till temps started to drop and to my surprise "Corsair Link" was the program. I remember changing this couple weeks back to run with Windows.
Here my results.
Has you can see here I was idle at 42c, opened Corsair Link and temps went higher.
Closed Corsair Link and Temps dropped a lot.
So if you find you getting higher temps at idle guys and use Corsair Link try closing it, they seems to be a conflict going on here.
I don't use Corsair Link, but my idle temps are much higher than they were when I was using 14.4 (currently using 14.6). I don't think the weather is entirely the cause, as the idle temps have risen considerably.
If I open a youtube video, I've seen idle temps of nearly 50C in some cases, where before it was nearer to the low 30's (in recent weeks).
