HIS 1950Pro 256mb AGP - Best drivers?
i'm using the latest ones from ati (7.6) the drivers that came on the cd seem to be faster (6.3 i think) but i get an error in event viewer - ati2mtag CPLIB :: HDCP - Failed HDCP key binding verification
what issues are you having?
if you haven't got decent airflow then the card can get hot quite qucikly,
keep an eye on your temps while playing with ati tray tools on screen display and post back what you get ;)
But running on normal stock value it shouldnt overheat. Not had any other cards in the past overheat.
Can you recommend any heatsinking or a fan for it to help out?
What would happen if I run on 100% fan all the time, not bothered about the noise as I use headphones.
the worst that can happen is the fan will start to rattle but mine only rattled around 70% and stopped at 100%.
also check that the heatsink is clear, i just took mine off as i have my water cooling running again and it was full of dust although my case is clean and uses filters.
what revision of the card do you have? if your not sure then post up the actual clocks that it runs at, HIS released a rev 2 card that has a lower core speed but higher mem speed. most of the first revision couldn't handle the 620mhz core clock so it was dropped to 580 i think.
ok try dropping the core speed down to about 580 and try it, if it stays stable then you have one of the cards that cant handle the factory overclock.
use ati tray tools and just underclock it to 580, leave the mem where it is for now until you know its stable.
if it stable at that speed then i would rma it unless your happy with it at that speed ;)
I will try that. IF I RMA it can I get a refund instead of a new one as I am not sure that I want another one of these if this is there quality?
Ill try that tonight. Thanks mate. You have been a real help.
Ok I ran the ati tool with stock drivers. You were spot on.
GPU Core at 573.75
Mem 742.50
benchmark 6150.15
Very stable
Run at normal default settings
Core being 630 something or near there
Mem 742.50
Crash and reboots half way through
What are my options?
well it doesn't run at the stated speed that it was supplied at so you have 2 options,
1 - RMA it, not sure if you will get a refund. send ocuk or where ever you bought it from a note asking if they can refund.
2 - keep it clocked at 580mhz, if they send you a new revision then all thats different is the core is at 580 and the mem is a bit higher than the rev 1 cards.
i suppose you could argue a refund as you bought it due to the fact it was pre overclocked and thats why you bought it and it doesn't run at those speeds so therefore its not the product you want.
have you got a link to that score? it whoops mine and i ran it at 675/817 with tweaked vga ram timings and my cpu at 2.57ghz
i have no idea tbh, i'm just looking at a new c2d setup myself but people have reccomended the asus p5k to me.
i thought your 3dmark score was a bit high for a single core amd chip lol
