HIS X1900XT problems - Hum/noise, DVI LCD problem, and fan speeds?
Hi,
Just got my HIS X1900XT from OcUK and I am having a couple of problems.
The first is that my LCD (Viewsonic VX910) with its DVI input doesnt seem to be working correctly with the Catalyst Drivers.
If I select "use centered timings" or "use monitor scaling" in the DVI options it makes no difference whatsoever, the picture is ALWAYS scaled to fill the panel, this is using ATI 6.8 Cats. Its pretty annoying to be honest as my old nVidia FX5900 had no problems running my LCD with centered timings. I had read that ATI's DVI/Flat Panel support was not as good as nVidia and it looks like thats correct.
Is there anyway I can get my monitor to use "centered timings" like my old nVidia card, so that resolutions lower than native (1280x1024) run in a box and pixel perfect with my ATI card?
The second is just as annoying, in 2D the card is nice and silent running away, but if I run in 3D (say Oblivion) it all looks fantastic yet the card emits a buzzing/huming/high pitched electrical noise, its actually not that loud but because I have built a pretty quiet system now its very noticable, if I move the mouse around (depending on graphic intensity of the view in Oblivion) the noise changes. (this is why my sound and speakers switched off). There is definately noise coming from the card, which isnt the fan. I did read about first gen 1900XTXs doing this, but I thought as not all people reported it that it was not a big issue.
Speaking of the fan, it seems to never run very fast, except for a brief second on bootup, is that normal?
So far, nice graphics and performance but not as nice usability as my old nVidia, and annoying electrical noises from the card which suggests its faulty or just a bad design.
Thanks,
Mike
Hi,
Thanks,
Mike
