Hitachi HDDs accessing while disconnected
Man of Honour
11 Mar 2003
Greenock, Scotland
Got a really bizarre issue here that I'm wondering if anyone else has seen before.
I've got 5 2Tb Hitachi disks which used to be in my media array, the array's been upgraded so I've got 5 spare disks to be used for backups etc. Now I've wiped and formatted the first three and they're all showing the same symptoms.
If I put them in the external dock thingy they're accessible fine and I can read and write from them no problem but whenever they're idle they start accessing yet nothing is showing in resource monitor, perfmon or anything else I can use. Strangely the accessing carries on even after a "safely remove hardware". Even more bizarrely I've just powered one up with no data connection back to the PC and it's accessing like crazy :confused:
So any ideas?
Out of interest, does the seeking stop after any length of time - maybe 10 minutes of seeking then it stops?
I have an external harddrive, which is also a 2TB Hitachi and it does exactly as you describe - I use the harddrive, during idle period it seems to seek for a while (never really timed how long for) then stops.
Which model harddrive is it? I'll need to check which model my external drive is, but I'm certain there is a firmware update which alleviate the problem, atlhough not entirely.
I've left the drives for hours and it's still been going on!
They're all HDS5C3020ALA632 / DS5SAD200, I think that's the 5K3000 series.
