HMDMI> DVI Audio??
I'd of thought the VGA cable would deliver the best picture out of all the cable. I have the official VGA cable and it looks great. You can go over 720p with the VGA but it goes to interlaced and the picture quality goes down. Halo 3 should look great has that support 1080p instead of 1080i.
it all depends on the device thats outputting the signal and what tv your sending the signal to. it varys with all combinations. for me dvi/hdmi is a bit sharper than vga on my screen
its just like some people prefering component over vga and vice versa
im sending it Via HDMI to my Gateway 24" HD PC monitor, via DVI. the DVI has HDCP. so im assuming this is what will give me the best results?
Got my cable, Got audio as AV cable, had to take the plastic off it to squeeze the HDMI plug in but its alright. Overall a LOT nicer quality, for some reason howver, 1080i gives me strange horizontal lines across the screen near the bottom. Theyre not overly noticable, but enough to make me want to get rid of them. these lines are NOT existant when on 720 though. hmm. ANy suggestions?
