hmmm what to do ?
Caporegime
1 Jun 2006
Notts
ok i got this budget of £240
would you get this
AMD Phenom II X3 Tri Core 720 Black Edition 2.8GHz (Socket AM3) - Retail
£90.99 inc VAT
Corsair Dominator XMS3 4GB (2x2GB) DDR3 1600C9D Twin3X
£72.99 inc VAT
Asus M4A785TD-V Evo AMD 785G (Socket AM3) PCI-Express DDR3 Motherboard
£70.99 inc VAT
total £234.97
or
AMD Phenom II X4 Quad Core 955 Black Edition 3.2GHz (Socket AM3) - Retail
£143.98 inc VAT
£70.99 inc VAT
OCZ Value 2GB (2x1GB) DDR3 PC3-10666C9 1333MHz Dual Channel (OCZ3V13332GK)
£26.99 inc VAT
total £241.96
on one hand id have a better amount of faster memory
other id have faster cpu and maybe upgrade mem with another 2gb arghh dunno what to do
do the 955 and the 720 work in that board straight out the box with no bios update ?
Whatever you do, get 4GB of memory, 2GB would be nuts (no matter what CPU you get) and you'll be chucking it out (selling it or upgrading) very shortly after purchase, can't you save up a little more?
q8200 + Asus P5Q Turbo + 4GB Kingston = £242
id say u might geta very slight boost in performance
I really would try to go for the quad-core... Can you save up a little bit longer, to make your purchase worthwhile? Or maybe consider buying second hand?
Personally I'd go for a Q9450 - decen't OCing and lots of cache, a P43 or P41 board or so unless you need the extra features... tho right now due to lack of stock availability on RAM at OcUK and needing a cooler for the CPU as the ones in stock are OEM it would push it a little above £240 - personally I'd reccomend the OCZ Blades for RAM if you can stretch to them.
LGA775 has another 2 years of support from Intel which is as good as your gonna get anyhow in this day and age...
Go with the second option (I just got that ram and its not green, its black) you can always add more ram. And I got that motherboard :D Very nice heatsinks on it.
