In JayzTwoCent's build, he has a hole in his shroud and a double ended fitting that allows fitting tubing to each side and appears to clamp around the hole.
You can see them here: https://i.ytimg.com/vi/xJiYl2WAN-0/maxresdefault.jpg at the bottom of the case
Can anyone tell me what these are called?
