hole spacing reference gtx 670?
Yeah, they just look a bit heavy for the reference 670 pcb - well the twin turbo does at least.
Wasn't particularly worried about it being a much better cooler than the reference, but less noisy definitely.
The Klara is lighter, smaller and cheaper than the accelero. Considering how awful the reference heatsink is, I can only imagine this being better, just was just not sure it would fit.
I do think it would, but not 100% sure.
Maybe will go accelero instead... dunno
Check this out it's KFA2 670 EX OC PCB
