HOLY CRAP!
29 Sep 2003
Newcastle upon Tyne
Please excuse the thread title, but I've just had the shock of my life. Installing Sims 2 on Vista, and my DVD drive suddenly gives out a huge *CRACK* sound like a firecracker, and I jumped a mile....
Look what came out when I opened the drive...
Needless to say, part of the CD is stuck in the drive, and it won't close. Oh my god, never in a all my years have I ever heard of this happening.
mrochester said:
I'm still in complete shock! Do you reckon it's worth opening the drive and removing the bits, or just get a new one?
lol, there will be bits all over the place in the drive, I'd get a new one. Looks like you have lost Sims 2 as well. Ea games crash everything, ea games spy everything, ea games advertise everything..... Yours is:
EA games break everything...
Lol, a fitting end to the disks life I think.
Aye get a new drive, there will be a ton of fragments in the drive and if your drive has done it once it will probably do it again, not worth risking expensive install disks for.
These are all the bits I managed to shake out of the drive... as you can see, large chunks are still in there! I think a DVD-RW might be on the Christmas list now...
it's not normally the drive, its the discs. Its a problem when your spinning a cd at 10k rpm - slight imperfections can lead to cracks....cracks can lead to bangs...you get the idea.
Slipping off the central spindal and impacting the inside of the drive bay at several thousand rpm does interesting things to plastic huh :p
Might not actually matter though, does the drive work fine even with the extra plastic?
Raikiri said:
You're lucky it wasn't a good game, maybe you'll be more selective in what you play in future ;)
It is a good game! I have all the expansion packs too.
I'm certainly not going to try. I think a new drive will be on my Christmas list now!
james.miller said:
it's not normally the drive, its the discs. Its a problem when your spinning a cd at 10k rpm - slight imperfections can lead to cracks....cracks can lead to bangs... bangs can lead to the dark side
...i may have edited that slightly :)
:p
ive had this happen to me though not with the sims 2 ;) .....i just took the drive apart blasted it out with a air line, reassembled and it still works fine and has been doing so for several months
This happened to me with me RA2 disk. I was going to RMA the CDRom drive, but I was just sent a new one straight away. I opened up the offending CDRom drive, extracted all the pieces of disk and it worked perfectly. Both drives are still in use today. :)
