Home built NAS with new Fractal case
Im looking at putting a zotac h55 in this case with a number of drives. I want it to sit in another room and act as a media server/nas. I have some questions for you guys :
1. Is it possible to also allow my girlfriend hook it up to a monitor so she can do some work on it ie office /visio etc or should she have a seperate system?
2. If she can use it what do i need to be aware of ie should i get her a seperate drive to store her work on?
3. If i put a zotac h55 in it what cpu would you recommend bearing in mind that this will feed 2 other pcs's one in the living room which will also be a md range gaming rig and 1 in the bedroom which will just be a htpc and nothing else.
This will be my very first build so any help you can give me is greatly appreciated, indeed the site has been a god send for me
Thanks
Thanks
It depends what OS you want to use. I've gone the Windows Home Server route so I have an Atom powered Mini-ITX box with room for four drives that is running WHS and all my media is stored on there. We then have a second PC that is used for gaming etc and finally an HTPC connected to the TV and AV Receiver. WHS makes the sharing easy and also adds a nice backup system that will even do bare metal restores but ideally it shouldn't be used for running Office apps.
That said with the sort of horsepower you're talking it would easily run Office/Visio whilst still acting as a media server. If you want to use WHS as the OS then you can install Office, you just have to make sure that anyone who logs into the box directly doesn't play with any of the Windows server settings or you could even go as far as installing something like VirtualBox and running a separate desktop OS like Windows 7.
What swung things towards a separate media server for me was the fact that I wanted to leave it on 24/7 and an Atom system uses so much less power.
I was going to use Win 7 across all with XBMC over the top?
Im settled on using the fractal design array as the nas/server - i would assume i dont need to add too powerful a cpu? maybe 4gb ram?
the gaming rig would obviously be more powerful and have a graphics card...just cant seem to find a decent micro itx board for a phenom and beyond...i guess there isnt one unless i go atx?
the rig in the bedroom would need a graphics card to help with decoding or would it...thinking of putting a zotac in that as well?
This is a nightmare trying to figure it out, the grlfriend defo wants access to office so the NAS/SERVER will need to support this i guess....
I dont know how you guys do it...as a mere mortal and novice this is tough :eek:
