Home cinema setup sub £750
233
233
21 Nov 2004
Wishaw
Looking to put together a 2.1 setup 4k receiver on a budget
no issue going for second hand kit but it’s a lot of choice to Wade through
need 4k pass through at a minimum as used with Xbox series X and occasionally virgin box.
hooked up to a Philips 65inch 4k set
Previously had a onkyo and mordaunt short setup and was very happy with the quality of that
many suggestions welcome
Ive been happy with my Dali Zensors for years. Can be picked up cheap enough now I expect.
Used to have the same setup, switched for a Denon 2400/Q Acoustics 3030i setup with Wharfedale sub (because the q acoustic sub is trash). Over your price range new for exact like for like, but both the receiver and speakers have more budget friendly options.
BK subwoofer could be had second hand for 250ish, such as an XXLS400, then 300 for an amp and the rest on the 2.0.
Zensors are great they have a warm tone to them with a smidge of mid range energy to them. I moved onto Ikons which are technically superior and you can learn their strengths (more accurate zensors with excellent treble extension) but the zensors are fantastic value and a great HT speaker. For pure hifi they're good side of average.
