Home cinema with 4K HDR player
  • Thread starter Thread starter X3T
  • Start date Start date
X3T
X3T
12 Sep 2011
So I'm new to home cinema/surround sound set ups for TVs, and I've been looking around for something suitable. I've noticed that all home cinema kits come with a Blu-ray player built into (what I assume is) the amp. The problem is none of them offer 4K support.
I want to buy a 4K player separately and then speakers, but either I'm missing something or there are no separate speaker kits for sale.
I only have a tiny living room, so I don't need anything powerful, but I do want high clarity and surround. I especially have problems hearing speech in movies.
Just buy a seperate AVR, BD player and speakers.
Second what furry said. But I would recommend something like a Yamaha 400 series AVR, it's basic with limited power, and speaker spring clips but what do you expect for such a low price.
There's someone selling some cube Wharfedale speakers on the members market, those would be a ideal for a box bedroom.
If you have problems hearing speech, get a quality center speaker, or use the dynamic range feature on AVR's.
If your living room is tiny, you might find placing the surround speakers properly is a faff. I would start with a pair of front speakers instead and build from there if you still want to.
As you were looking at an all in one kit, I'm guessing you don't want to spend a lot of money on this. Richer Sounds is selling the Yamaha RXV381 for £149 to its VIP members; add a pair of Wharfedale 9.1s and you'll have a good system for a small room. You can add a matching centre later if the dialogue isn't clear enough.
Thanks all, never thought of buying separately. In my head they all had to be compatible or something.
Makes sense to start with just front speakers and see how it goes. Yeah I don't want to spend loads on this!
Personally i'd go for floorstanders over standmounts.
Budget?
Depending on budget. For lower budget, then budget floorstanders are nothing great- the money would be better spent on standmounts.
You need to spend a fair amount more on floorstanders to get the same quality.
I presume his budget is about £100- so buy standmounts. You won't get a good set of floorstanders for that price.
I've owned quite a few floorstander and standmounts. Brands have been
B&W
Celestion
Kef
Wharfedale
Ruark
Also you could buy second hand, I've bought most of my speakers either second hand or demo, you save a lot of money and you'll get more for your money.
Yeah, t'is why I chucked the budget question in.
If its under 500 all in then standmounts are the way to go. Leaves 150 for an avr, 200 for the 4k player and 50 for stands and cable.
Sorry I didn't see these posts!
So I currently have just the Yamaha RVX381 AVR (£149!), some decent copper audio cable and premium certified HDMI cables.
I'm looking at the Sony UBP-X800 player, Wharfedale Diamond 9.1 speakers, Mission Stancette stands and literally no idea about the TV yet. It started off just wanting a new TV and 4K player, but then I thought about looking into proper audio for the first time (I've only ever used the built in TV speakers). Current TV is some LG 32", but I'm probably looking for a 4K HDR 43-49".
Total budget is around £1400:
  • £600-650 for TV
  • £350 for 4K player (Sony X800)
  • £150 for AVR (Yamaha RVX381)
  • £100-£150 for speakers (most likely Diamond 9.1)
  • £60 for stands (Mission Stancette)
  • £30 for miscellaneous stuff (cables, etc..)
The player is rather pricey but after much research that's the one I'm quite keen on.
If your are considering thw sony as a 4k player , unkess its to play sacd id go for the
Panasonic DMP-UB900EB 4K Ultra
Its on VERY atm for £369.
Its in stock on the rainforest as well
Kicks the Sony's behind
Probably a discount for new account as well
...premium certified HDMI cables.
Just so you know for the future, HDMI is a digital standard and will work as well as it possibly can on any cable that isn't damaged. I've been using £2 cables from eBay for years and never had a problem.
I've had issues in the past running high bandwidth content over cheaper cables, so to save any concerns this time I went for certified cables. Might not be necessary as you say, but I didn't want to risk it again!
  • £600-650 for TV
  • £350 for 4K player (Sony X800)y
Hi Bud...
I'll try and give you some advice on this topic.
  • Television
    As you're going for 4K, it's really important you buy one which can truly do HDR justice. Many TVs have "HDR" in their sales title but in reality hit 200-400 nits max in peak brightness and have an 8-bit panel.
    You want a TV which is Ultra HD Premium Certified, something which can hit 1000nits peak brightness (Slightly lower for OLED) and has an 10-bit panel. This could affect your budget a little, i personally have the Samsung 55" KS7000. If you can't afford one, give up on 4K for now until you can, resolution gives you little benefit. It's HDR and done properly which gives you that "wow" factor, otherwise you'll struggle to notice a different.
  • 4K Player
    What are you looking to do with a 4K Player? Is it just play UHD no specialist stuff.. If so i'd go for an Xbox One S, it represents great value (especially 2nd hand) and does the job every other player will do. It even supports Atmos now. There really is no point spending £350 on a 4K bluray player.
  • Speakers
    Since you've got an AVR already, i wont go into that but the RXV381 is definitely a good starter receiver.
    Speakers... You want to up your budget in this area in my opinion. £100/£150 is too low. The £200 you save on buying an Xbox One S, put into your speaker budget to push it to £350.
    Buying speakers is a highly personal and subjective thing, its not just sound but the style of speakers you prefer and room size / shape. How big is your room? What kind of style do you prefer? Bookshelf? Satellite Style speakers?
    I personally have the KEF 3005SE 5.1 set - but i like style speakers which blend better into the room. For any first timer, looking to enter at a low price point and experiment i'd say avoid floor-standers. Unless you've got a very large room.
Hi Bud...
  • Television
  • 4K Player
  • Speakers
Thanks for the info. I've read up on what you said about HDR, I had no idea. Looking around it seems Samsung have the most options for certified TVs with the appropriate brightness.
Seeing as though the TV is the "centrepiece" I would probably up the TV budget to get a decent one if I were to go for the Xbox as the player, rather than the speakers. I'm going for 2ch/stereo to start with, in a tiny living room. I can upgrade the speakers later but I've only ever used built in TV speakers, so anything is an upgrade!
What do you think of the Samsung KS9000 49"?
