Home Network Advice
6 Jan 2013
Rollergirl
I have 3 devices that are all connected to the local network.
2 * Windows 10 PC's
1 * WD MyCloud
What's the easiest way to get them in a place where I can go to any of the 2 PC's and drag and drop files to and from any of the other 2 devices?
Homegroup is cumbersome and not much of a solution.
Probably mapping them or a specific part of them to a drive letter etc.
I've got specific folders mapped to drive letters from my nas and my fritzbox usb port (fritznas) and can obviously do the same with other pc's if I want.
All I did was make sure they're on the same network and workgroup (I'm win 10 pro for reference) along with making sure they're discoverable (there's usually a pop up asking yes or no). Then it's just the usual mapping of folders from a network location etc.
It seems to work pretty well for my usage.
OK so how to you access files on it now? It must have some kind of interface. Presumably you can just do "\\<IP of WD cloud>" in Explorer?
