yeah it is, and some streaming, until i had the hub 5 ive never had a network device with gigabit and it's always been fine so i'm not too concerned, i think i will need to run a cable between hub and bt tv box as i think it needs gigabit, i didn't get it working with an old sky router used as a switch.
Just need a couple of wifi access points now as i find the wifi on it pretty poor.
I have some 2 gang faceplates to install for a couple of Cat5e cables. Will any Cat5e module fit in the faceplate? Or do they have to be from the same brand? The brand of faceplate I have only sell Cat6 modules and I've read that they are not 100% backwards comparable with Cat5e modules due to the individual cable diameter.
Edit:
Unless I can be corrected on my view that the Cat6 module won't be compatible with Cat5e cable..?
They are Screwfix's LAP brand. I went with their sockets and switches for part of the rewire and would ideally like to keep to the brand for the sake of ensuring the colours match.
