home network setup
11 Jan 2005
Birmingham
After bothering before and getting nowhere, and just completing a 10hour networking exam I feel i should get my home network sorted for once.
I've only ever got the pc's to see each other once and then oneday they couldnt again.
Both are on same "workgroup" : PSYNET
ip ranges are fine: solar:192.168.1.100 // psypher:192.168.1.101
on my bebox it can see both computers, and it sets dns etc etc up auto.
Now, my main rig (psypher) is vista, sets up the network being able to view itself and the speedtouch bebox via lan connection.
moms pc, solar, is on xp and has an internet gateway and a lan connection, cant see psypher at all.
both can ping eachother fine.. so any ideas?
OK - is this how it is?
BEBOX can see PSYPHER and SOLAR - can you access shares on these? or just see them on the network? (I'm assuming that BeOS uses some form of SaMBa...)
SOLAR cannot see either PSYPHER or BEBOX
PSYPHER cannot see SOLAR but can see BEBOX
(I think...)
Can either SOLAR or PSYPHER see shares on each other? They can ping each other, so can you UNC to each other - whether that's by netbios name or ip address?
sorry, be box is the router from my isp :P
cant share files or anything such like samba etc. Should have mentioned that!
Both pc's can see the router (bebox)
but cant see eachother
can ping eachother and get a response
the "network" view shows no other wordgroup pc's etc
sorry for the confusion ;)
for some random reason since today on moms pc, i type in http://bebox to connect to the routers gui, it links to that wiki page :D
disabled firewall on both pc (windows and nic) also set up to allow print sharing on a different occasion, still wouldnt see each other.
Vista pc first (ill run down and cmd solar in a sec)
Code:
 C:\Users\Tom>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : psypher
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : NVIDIA nForce Networking Controller
Physical Address. . . . . . . . . : 00-13-D4-AB-4D-8A
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::c8c9:3353:7c5c:a7c0%8(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.101(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 11 May 2007 12:24:22
Lease Expires . . . . . . . . . . : 12 May 2007 12:24:21
Default Gateway . . . . . . . . . : 192.168.1.254
									 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 134222804
DNS Servers . . . . . . . . . . . : 62.31.176.39
									 194.117.134.19
									 195.188.53.175
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection 3:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Marvell Yukon 88E8001/8003/8010 PCI Gigab
it Ethernet Controller
Physical Address. . . . . . . . . : 00-13-D4-AB-61-13
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 6:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
Tunnel adapter Local Area Connection* 9:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Link-local IPv6 Address . . . . . : fe80::5efe:192.168.1.101%18(Preferred)
									 194.117.134.19
									 195.188.53.175
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter Local Area Connection* 11:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter Local Area Connection* 12:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter
C:\Users\Tom>
Solar:
Code:
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Tom>ipconfig /all
		Host Name . . . . . . . . . . . . : SOLAR
		Node Type . . . . . . . . . . . . : Unknown
Ethernet adapter Local Area Connection 5:
		Description . . . . . . . . . . . : NVIDIA nForce MCP Networking Contro
ler
		Physical Address. . . . . . . . . : 00-30-04-04-85-0E
		Dhcp Enabled. . . . . . . . . . . : Yes
		IP Address. . . . . . . . . . . . : 192.168.1.100
		Default Gateway . . . . . . . . . : 192.168.1.1
											194.117.134.19
											195.188.53.175
		Lease Obtained. . . . . . . . . . : 11 May 2007 14:24:53
		Lease Expires . . . . . . . . . . : 12 May 2007 14:24:53
look fine to me...
Go to network connections and view the properties page - do you have Client for Microsoft Networks and File and Printer sharing for Microsoft Networks listed?
Are you using the *any* other firewall software? (The router's HW firewall does not matter here) And is the windows firewall definitely disabled?
Why are your gateways different on the two machines? Psyphers gateway is 192.168.1.254 (should be 192.168.1.1) whereas solar is 192.168.1.1 as expected.
