I have been having some issues with my network lately so think it’s time to do some upgrades but not sure where to take things.
Wifi is used quite a lot and I do have some dead spots but I’ve also got home plugs being used that probably need replacing and maybe a better switch.
Current kit is a Sky Q Hub router on which I’ve disabled DHCP and I use my AirPort Extreme AC. This was fine but then as we got more wired and wireless devices things started to fail. I purchased a 2nd Apple router which I was using with a home plug to provide wifi down stairs but this strangely performed better just extending the wifi wirelessly.
I have a NAS and couple of home servers in the garage, the plan is to run a cable from the office to there to replace the home plug which is about the only upgrade I am sure of.
What I am not sure of is my existing 3 routers and if I should either invest in a mesh network or could I purchase a better extender and/or make use of existing Hardware. I only live in an average size 3 bed detached and would like to also reach the back garden (office is back of house) but I’ve seen well priced outdoor access points.
Wireless the performance is required in the living room for the nvidia shield, consoles and Xbox and this where I have issues. I would also like a good signal for my MacBook and iPad but anything else like phones will just be browsing and very little streaming. The garden doesn’t need streaming either, probably just for browsing and maybe streaming locally (Plex).
Anyone got any upgrade suggestions or configuration of existing kit. I am planning to run cables in the loft for the IP cameras I’ve not installed so would consider doing a drop from the loft down to the living room if a hard wired access point is required but ideally I want to get away with providing better wifi wireless.
