Suspended
- 6 Sep 2016
"Pre-outs require a secondary amp. An AV receiver with Zone 2 does not."
Pre-outs can function to zone 2, that's the point. Nothing you using pre-outs to a amp, into zone 2. Or headphone amp.
Also what of AV pre-amps with Zone 2 outputs? They offer zones they just need amps, so no difference between a old school stereo analogue pre-amp, with say a multi-channel amp for main, zone 2, zone 3 etc.
Both can function as "zone 2" they may differ but they can do the same function. You could use pre-outs into a distribution amp. How is that not "zone"
"A+B Speaker only allows one source to be played in A/B or A+B."
True, but that can still function as multi-room, just means the same audio. Which some people or installs are used for. Sure it doesn't offer seperate sources that is a limitation but not everyone needs that.
"An AV receiver with Zone 2 allows different sources to be played in the two zones at the same time."
You just stated not all AVR's have that, or require analogue sources.
So if I had a BD player, with no analogue outputs, and a TV box with no analogue outputs, how would I send audio to zone 2? You can't.
"Zone 2 has been around for a long time, and people are using it now more than ever because music and audio is increasingly a whole home connected technology."
I have multi-room myself. Squeezeboxes (two of them) they can either play the same track, or different tracks. And because both are seperate, I can use other sources on both amps too.
Slim Devices also offered audio media streamers, at the time Squeezebox offered more, for more affordable pricing. The requirement for a server/service was a pain, but Sonos LCD remote was very expensive, it had no VFD, and squeezebox was open, Sonos was closed system.
It's better now of course, and Squeezebox is end of life although it still functions as needed.
"If RFI were to become a problem then there's always the fall-back a balun system which uses balanced CAT cable to deal with noise. Real world solutions rather than negativity. "
Or you could use optical or coaxial out from the AVR or DAC (bypass out) to the next room, into another DAC or AVR. Single cable, and not effected by noise, loss etc (esp optical) Plus pass DD/DTS.
"Are you aware that integrated AV amps and AV receivers with multi-room features have been available since 2000-2001 though?"
Yup. But if they require analogue and digital, they are flawed in my opinion.
My Lexicon does the same, it needs analogue and digital to get zone 2 to work. It's stupid. I believe the MC-12 allowed you to send audio to other zones.
There are many ways of having multi-room, different methods, and if something doesn't work - then need to figure another way of doing it. If your method doesn't function as it should, because of the hardware limitation then use another way. My method isn't wrong, it just has more flexbility.
