- 26 Apr 2004
- Milton Keynes
Home recording studio queries - what do I need, and how, read inside for more...
At my house, the garage is unused, and me and my dad eventually plan to put a floor into the room (at the moment its concrete), and I'm thinking of turning it into a sound studio, as I study Music Tech, and while not particularly amazing at playing, I LOVE to tinker with equipment, equalisers etc to get the best sound, even if my musical skills and design arent good.
I already have CubaseSX 3, and have come up with the following other things I'd need to make this a reality, but my knowledge is somewhat limited, so I'd really like to learn and for you guys to tell me what else I'd need.
The PC I'd be using is my current one, which Im replacing soon (so I could use my current one as a music editing job).
List of equipment I came up with was:
2x Monitor Speakers for PC/Mixing Desk (NEED RECOMMENDATIONS)
Mixing desk 8 Mono Channel Minimum (8 mic input), 16 channel maximum, pref with eq, phantom power, panning and FX if possible (NEED RECOMMENDATIONS) - Thinking Behringer Eurorack
Professional Looking Desk designed to hold Mixing Desk, Monitor and Keyboard and Mouse
3x Shure SM58 vocal mics
3x Shure SM57 instrumental mics
PC (AthlonXP2800+,1GB RAM, 160GB HD, Soundstorm, 9200 gfx, CD Burner when I strip it down for better cooling)
New sound card (to recieve info from mixing desk) (NEED RECOMMENDATIONS) - M-Audio or X-Fi Fatality likely
Cables (NEED RECOMMENDATIONS)
Microphone stands/clamps (NEED RECOMMENDATIONS)
Headphones so artists and I can hear exactly what is being played, like from the monitors (NEED RECOMMENDATIONS)
Phantom Power Condensor Mic?
Drum Kit Mics (NEED SUGGESTIONS)
Also thinking of getting a remote Network Storage device for audial backup.
Obviously the players bring thier own Amps for me to mic up, and I already have a drum kit within the household.
Can you guys please give me suggestions, ie sound card, and can you tell me what I'd need to do to connect the seperate channels on the mixer to a seperate channel on Cubase?
Is there a sound card etc with 6 inputs, or do you just record each input seperately, or DI into the mixer, play all at once, and that outputs in stereo (over a phono/phono lead to the sound card)?
Also, do you recommend a dual monitor setup for the computer?
Also, what mics do you recommend for rigging a drum set?
Does anyone have a good website with a good layout of how they believe one should be mic'ed, and what cables do you lot recommend?
As you can see, on the fine details I'm completely out of my depth so far, so please give me all the knowledge you've got, I love to learn about this stuff, and I wanna make sure when this project happens, its done ok, not badly.
My overall budget for this project will probably be about £1000 max, and ebay will be my friend (can get new Shure mics on there for about £40-50 each!)
For referance, the garage we'd be using as a studio if this project is ever completed is about 10m x 10m.
Also, obviously, HAVE I MISSED ANYTHING?
So, Creative or M-Audio...
