lozza23_uk said:
behringer is great stuff. the preamps are fairly quiet. loads of groups on them as well.
but be prepared for it to go wrong. they always seem to break channels easily.
so cheap though it is rude not to.
Here are some more ideas:
This is basically the ProjectMix without the faders
http://www.dolphinmusic.co.uk/page/shop/flypage/product_id/3803
http://www.soundonsound.com/sos/Oct04/articles/maudio1814.htm
Nice bundle including Behringer 8-channel Preamp & A-D/D-A Converter:
http://www.dolphinmusic.co.uk/page/shop/flypage/product_id/4122
http://www.soundonsound.com/sos/jun04/articles/behringerada.htm
Now - I'm not a fan of Behringer at all. The stuff I've used has been put together with gaffer-tape and string, sounds like a wet turd on holiday and breaks in about 30 seconds. This unit sounds OK from the review in SOS though.
I would *again* seriously think about why you're buying a desk.
Is it just because that's what you associate with a *studio*?
The reality is that, yes, customers expect to see a 'desk'. But in reality, the vast majority of mixing these days is done using automation anyway (desks in big studios are all automated - unless they are *real* traditionalists and still enjoy roping in the tape op to move faders for big mixes
If I were you I would just draw a big desk in crayon on a piece of card and pretend
I'm just trying to stop you spending cash that you say you can't afford to waste.
So many of my mates have bought desks/mixers that they just use for a few pres and master volume and envy the amount I saved by not buying one!
Are you *really* going to use that desk to do mixes on? If so, why did you spend a fortune on Cubase SX3, which, if you press F3, will give you a superb desk with half-decent EQ, inserts, all the bus routing options you need (with no bloody patch cables requiring playing with and degrading the sound), etc etc!
The *only* reason for having a desk is to move more than one fader at a time, and for the *feel* of analogue mixing. This is luxury to me - as you generally mix one thing at a time in reality, and can do complex mixes with automation.
Seriously - for a small project studio, if your emphasis is on quality, the best bang for buck lies in outboard pre's.
