Home Security
Not connect it to the internet? ;)
PfSense firewall is probably a good start if you don't want to spend the money on a commercial unit. Any Wifi shouldn't broadcast itself either.
what are the benefits of the expensive hardware solutions? And how expensive are we talking? Thanks
The benefits they offer are more options regarding security - for example pfSense is a good firewall, quite a few work environments use it.
Although, for a home user I wouldn't have thought you'd need more than your standard router - don't broadcast the SSID, have a decent password, set up MAC Address filtering etc.
MAC address filtering as a layer of security is pointless. It's easy to spoof a MAC and when a device broadcasts a packet, it contains the MAC of the device anyway.
You're far more likely to have a security issue originating from inside your network than someone breaking in from the outside.
Waste of time.
Yup I'd echo that.
http://www.howtogeek.com/howto/2865...hiding-your-wireless-ssid-really-more-secure/
For home use then there's not really much needed, I do still use MAC filtering white list and WPA2 for wireless, other than that just really rely on my router for everything else.
Main thing I'd say is just make sure you're keeping software up to date.
Could potentially stick an IPS in there as I have access to the kit/software, but it's not needed (might do it sometime out of curiosity).
