Homemade Chocolate Éclairs
Caporegime
25 Jul 2003
FR+UK
This is a nice little thing to be able to make, as once you've mastered choux pastry you can make quite a few nice desserts with it. Apologies for the presentation but I can assure you they taste great :p.
Ingredients
This makes twelve éclairs, and takes roughly 30 minutes.
The pastry
  • 70g plain flour
  • Pinch of salt
  • 50g butter
  • 150ml water
  • 2 eggs
The filling & topping
  • 300ml double cream
  • 2 tsp icing sugar (sifted)
  • 1 tsp vanilla extract
  • 115g plain chocolate
  • 2 tbsp water
  • 25g butter
Baking
Preheat the oven to 200ºC. Grease and lightly flour a baking sheet and place on a tray.
To make the pastry: On a very low heat, melt the butter and water in a pan, and once melted together bring to a boil. Remove the pan from the heat, and add the flour, immediately beating them together.
Return the mixture to a low heat, and continue to beat until it forms a small ball. Remove from the heat, and allow the mixture to cool for a few minutes before folding in and beating the eggs thoroughly.
Pipe the mixture out into thin éclair like strips, cutting each one off with a wet knife/wet scissors.
Bake for 20 minutes, or until golden brown, and then take them out of the oven and slice them most of the way through. Place them back in the oven for 5 minutes at 175ºC.
Place on a wire rack to cool.
In the mean time, prepare the filling and topping. For the filling, whip the ingredients together (Cream, Vanilla Extract, Icing Sugar) until it holds its quite thick and can hold its own form:
Melt the chocolate with the water and butter in a bowl over water on a very low heat:
Pipe the mixture into the éclairs.
And then dip the éclairs into the chocolate mix, and place back on the rack to allow the chocolate to solidify.
I like eclairs and its a good effort but I'm going to be critical and say the presentation is poor.
I think the chocolate is too runny and diluted otherwise the rest is great.
great stuff, another cook is in the midst :D havent tryed making those yet, i might, but like them from tesco ready made. however i did make carrot cake once :D
I just used this recipe to make profiteroles. So so so so nice :p Sadly I only ate three of them before feeling pretty sick :D
I changed the chocolate slightly so that it had less water and butter mixed in with it. This kept it quite a lot thicker (ended up very similar to the chocolate you get on store-bought profiteroles, only way nicer). I also used milk chocolate due to not reading the recipe properly. However, I think it worked okay on profiteroles, whereas eclairs would really need the dark chocolate.
I ended up with about twice as much cream as I needed so I'd advise anyone else to double the quantities of the other ingredients too (this would make enough profiteroles for about 8 people easily).
Yep you're quite right, I'd added to much water to the mix so the chocolate topping was poor.
They're making me feel hungry :(
If it makes 12 how comes you only made 10 ?
MW
Some may have accidentally fallen casualty to a taste test...:p.
I always find up to 1 teaspoon of water is usually enough, any more & choccy becomes too runny.
As for choccy, I like to use ASDA Extra Special Dark Cooking Chocolate (150g) about 87p.
