Homeplug question.... Two devices into one plug?
15 Nov 2003
Marlow
If I want two devices in my lounge to have internet access via a homeplug? Do I have to use two plugs - ie: Each device needs their own plug?
So would I have to have one plug where my router is, and then two in my lounge?
Or is there an simpler way of both my lounge devices sharing the plug?
Thanks... yet another device to plug into the wall :)
Got to wonder how much energy all these homeplugs and switches just sit there using :confused:
5 watt maximum, 3.3 watts in standby for my Devolo ones. Not sure about my switch, probably not much as its built into my router. (ah, 12v at 1 amp apparently so 12watts.)
Hmmmm... So that would be another 20 or so watts all day long...
you can get routers with the homeplug built in, pretty easy to configure them as a switch if your short on wall plugs
