Hope right forum- SD Card question
18 Oct 2002
Manchester
is it possible to convert an SDHC Card into an SD original format. I was just wondering as I want to use a card in and "older" version of software that only reads the original SD format.
Would changing the format to FAT32 make any difference, the reason I am asking is that to get hold of the original format cards you are talking serious bang for buck.
Anyway if anyone can help I would appreciate it?
SDHC is High Capacity, just the amount of space on there. do you have access to MM? Bound to be people out there with some in a drawer.
