Horrible, horrible, horrible X1900XT problem: no signal over DVI since driver upgrade
Here's mine notice anything missing on yours?
It's not detecting your DVI connection.
Hi, thanks for posting the image, that's really helpful. The driver doesn't detect the Digital input of my monitor at all, even with it and the VGA connection plugged in at the same time. Because of this I don't have the 'Digital Panel Properties' menu, which is obviously frustrating.
I have a feeling that I will either need to RMA the graphics card or the monitor. However, I am not sure which. Hopefully ViewSonic and ATI tech support can help me sort this out without having to resort to dealing with RMA's...
Driver profile for the monitor?Is it standard monitor or is it specified by manu and model No?
If its not detecting DVI port on monitor properly that is really your only chance i believe ( rma'ing monitor)
Forn - do you have any idea what DDC is on your X1900 - I only have "Secondary" here and wonders what that means
I have the ViewSonic driver for Xp x64 loaded, which is being picked up when I use VGA.
DVI works perfectly when the ATI driver isn't loaded so it's odd that it doesn't work when the driver is loaded. Mu best guess from the research I've done is that there is a conflict in the EDID that the monitor is reporting and what the graphics card is reading, as I have illustrated above. However, it's above my ability to fix it.
DDC seems to stand for "Display Data Channel":
http://en.wikipedia.org/wiki/Display_Data_Channel
One of my housemates might have a computer suitable to testing the monitor over DVI but I've not seen him for a week or so. When I next see him, I'll ask.
Go and get this, I use it to get the highest res settings for HDTV's.
http://entechtaiwan.net/util/moninfo.shtm
It will give you all the DDC info from the panel.
First off, I don't think its the GF card. I'd bet that if you plugged you panel in via DVI and a second analogue monitor in next to it. Then you get to the DVI mode switch via the analogue screen, or at least get a resolution/frequency that works. It may be that when the monitor is connected with VGA it disables the DVI output.
Right, I am home now. However, no sign of the phantom flatmate. When I next see him, I'll ask to do two things. First of all to try my monitor out over DVI if his computer can output it, and secondly to use his monitor with mine to see if I can get some DVI mode goodness.
I have received another reply from ATI. Here's what they have to say:
It does sound like the card you have is defective and should be replaced. If you install the previous drivers that you were using that worked and it does the same thing, the card needs to be replaced.
Thoughts? I am not totally sure it is the card personally and will try all available avenues to fix it without having to RMA it, which would be a pain.
This is what MonInfo reports:
Monitor
Windows description......... ViewSonic VX912
Manufacturer description.... VX912
Manufacturer................ ViewSonic
Plug and Play ID............ VSC8D1A
Serial number............... PPE050200086
EDID data source............ Registry (stored)
Manufacture date............ 2005, ISO week 2
EDID revision............... 1.3
Display type and signal..... Analog 0.700,0.300 (1.0V p-p)
Sync input support.......... Separate, Composite, Sync on green
Screen size................. 380 x 300 mm (~21")
Power management............ Active off/sleep
Color characteristics
Display gamma............... 2.20
Red chromaticity............ Rx 0.634 - Ry 0.354
Green chromaticity.......... Gx 0.287 - Gy 0.621
Blue chromaticity........... Bx 0.138 - By 0.077
White point (default)....... Wx 0.313 - Wy 0.329
Timing characteristics
VESA GTF support............ Not supported
Horizontal scan range....... 30-82kHz
Vertical scan range......... 50-85Hz
Video bandwidth............. 140MHz
Extension blocks............ n/a
Timing recommendation #1.... 1280x1024 at 60Hz
Modeline................ "1280x1024" 108.000 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync
Standard timings supported
640 x 480 at 60Hz - IBM VGA
640 x 480 at 67Hz - Mac II
640 x 480 at 72Hz - VESA
640 x 480 at 75Hz - VESA
640 x 480 at 85Hz - VESA
720 x 400 at 70Hz - IBM VGA
800 x 600 at 56Hz - VESA
800 x 600 at 60Hz - VESA
800 x 600 at 72Hz - VESA
800 x 600 at 75Hz - VESA
800 x 600 at 85Hz - VESA
832 x 624 at 75Hz - Mac II
1024 x 768 at 60Hz - VESA
1024 x 768 at 70Hz - VESA
1024 x 768 at 75Hz - VESA
1024 x 768 at 85Hz - VESA
1152 x 864 at 75Hz - VESA
1152 x 870 at 75Hz - Mac II
1280 x 1024 at 60Hz - VESA
1280 x 1024 at 60Hz - ViewSonic
1280 x 1024 at 75Hz - VESA
Raw EDID base
00: 00 FF FF FF FF FF FF 00 5A 63 1A 8D 01 01 01 01
10: 02 0F 01 03 0E 26 1E 78 2E 68 75 A2 5A 49 9F 23
20: 13 50 54 BF EF 80 81 80 71 4F 61 59 45 59 31 59
30: 01 01 01 01 01 01 30 2A 00 98 51 00 2A 40 30 70
40: 13 00 78 2D 11 00 00 1E 00 00 00 FF 00 50 50 45
50: 30 35 30 32 30 30 30 38 36 0A 00 00 00 FD 00 32
60: 55 1E 52 0E 00 0A 20 20 20 20 20 20 00 00 00 FC
70: 00 56 58 39 31 32 0A 20 20 20 20 20 20 20 00 3C
Display adapter
Adapter description......... Radeon X1900 Series
Adapter device ID........... 0x72491002
Display settings............ 1280x1024, 32bpp
User/computer information
Registered user name........ Oliver Woolf
Registered organization..... Home
Network user name........... Administrator
Network computer name....... HOME-3MB5R6SA5J
Windows version ............ Windows XP
Windows build .............. 5.02.3790 Service Pack 1
Installation date .......... 17/04/2006 12:00:00
Is there anything I need to act on regarding this?
Thanks everyone,
Oliver
Back it up a bit. Try the moninfo when the DVI is working i.e safe mode. The above is a normal report from the VGA, nothing special. Maybe you need to select the secondary output, there is a drop down select when two or more are available.
Unfortunately the monitor doesn't seem to be detected in safe mode, here's the moninfo read out:
Monitor
Hardware information........ n/a
Display adapter
Adapter description......... Primary port
What does this mean? I assume that it points to my monitor definitely being the source of the problem?
Thanks,
Oliver
Hold on. Did you disconnect the VGA? One DVI connection in safe mode, yes?
roadie said:
DVI works fine under safe mode and in normal Windows with no driver.
Get back to that point and run moninfo. If you did already you have a monitor problem.
Yeah, I did disconnect VGA to make sure that it used DVI when booting into safe mode :(
What do you think the next step should be?
Thanks for all your help by the way,
Oliver
This is the one from the HDMI on the HTPC I'm typing at, so you can see what a digital repot looks like.
Monitor
Windows description......... Plug and Play Monitor
Manufacturer description.... TSB-4Xs
Manufacturer................ Toshiba
Plug and Play ID............ TSB0501
Serial number............... n/a
EDID data source............ I2C bus (real-time)
Manufacture date............ 2004
Display type and signal..... Digital
Sync input support.......... n/a
Screen size................. (~102")
Power management............ n/a
Display gamma............... 1.00
Red chromaticity............ Rx 0.640 - Ry 0.330
Green chromaticity.......... Gx 0.300 - Gy 0.600
Blue chromaticity........... Bx 0.150 - By 0.060
Horizontal scan range....... 15-46kHz
Vertical scan range......... 49-61Hz
Video bandwidth............. 80MHz
Extension blocks............ 1
Timing recommendation #1.... 1920x540 at 50Hz
Modeline................ "1920x540" 74.250 1920 2448 2492 2640 540 574 579 562 +hsync +vsync
Timing recommendation #2.... 1920x1080 at 25Hz
Modeline................ "1920x1080" 74.250 1920 2448 2492 2640 1080 1148 1158 1124 interlace +hsync +vsync
Timing recommendation #3.... 720x576 at 50Hz
Modeline................ "720x576" 27.000 720 732 796 864 576 581 586 625 -hsync -vsync
Timing recommendation #4.... 1280x720 at 50Hz
Modeline................ "1280x720" 74.250 1280 1720 1760 1980 720 741 746 750 +hsync +vsync
Timing recommendation #5.... 720x576 at 50Hz
Timing recommendation #6.... 1920x540 at 60Hz
Modeline................ "1920x540" 74.250 1920 2008 2052 2200 540 542 547 562 +hsync +vsync
Timing recommendation #7.... 1920x1080 at 30Hz
Modeline................ "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Timing recommendation #8.... 720x480 at 60Hz
Modeline................ "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
Timing recommendation #9.... 720x480 at 60Hz
720 x 480 at 60Hz - Toshiba
720 x 576 at 50Hz - Toshiba
1280 x 720 at 50Hz - Toshiba
1920 x 540 at 50Hz - Toshiba
1920 x 540 at 60Hz - Toshiba
1920 x 1080 at 25Hz - Toshiba
1920 x 1080 at 30Hz - Toshiba
Raw EDID base
00: 00 FF FF FF FF FF FF 00 52 62 01 05 00 00 00 00
10: 00 0E 01 03 80 C4 8E 00 0E EE 91 A3 54 4C 99 26
20: 0F 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
30: 01 01 01 01 01 01 01 1D 80 D0 72 1C 16 20 10 2C
40: 25 80 C4 8E 21 00 00 9E 8C 0A D0 90 20 40 31 20
50: 0C 40 55 00 C4 8E 21 00 00 18 00 00 00 FC 00 54
60: 53 42 2D 34 58 73 0A 20 20 20 20 20 00 00 00 FD
70: 00 31 3D 0F 2E 08 00 0A 20 20 20 20 20 20 01 E9
Raw EDID extension (CEA-861)
00: 02 03 1C 77 4D 94 13 12 16 11 15 05 04 03 07 02
10: 06 01 23 09 07 07 65 03 0C 00 10 00 01 1D 00 BC
20: 52 D0 1E 20 B8 28 55 40 C4 8E 21 00 00 1E 8C 0A
30: D0 90 20 40 31 20 0C 40 55 00 13 8E 21 00 00 18
40: 01 1D 80 18 71 1C 16 20 58 2C 25 00 C4 8E 21 00
50: 00 9E 8C 0A D0 8A 20 E0 2D 10 10 3E 96 00 C4 8E
60: 21 00 00 18 8C 0A D0 8A 20 E0 2D 10 10 3E 96 00
70: 13 8E 21 00 00 18 00 00 00 00 00 00 00 00 00 30
EIA/CEA-861 Information
Revision number............. 3
DTV underscan............... Not supported
Basic audio................. Supported
YCbCr 4:4:4................. Supported
YCbCr 4:2:2................. Supported
Native formats supported.... 7
DTV formats supported....... 13
CE standard timings supported
1920 x 1080i at 50Hz (16:9) - HDTV (Native)
1280 x 720p at 50Hz (16:9) - HDTV
720 x 576p at 50Hz (16:9) - EDTV
720 x 576i at 50Hz (16:9) - Doublescan
720 x 576p at 50Hz (4:3) - EDTV
720 x 576i at 50Hz (4:3) - Doublescan
1920 x 1080i at 59.94/60Hz (16:9) - HDTV
1280 x 720p at 59.94/60Hz (16:9) - HDTV
720 x 480p at 59.94/60Hz (16:9) - EDTV
720 x 480i at 59.94/60Hz (16:9) - Doublescan
720 x 480p at 59.94/60Hz (4:3) - EDTV
720 x 480i at 59.94/60Hz (4:3) - Doublescan
640 x 480p at 59.94/60Hz (4:3) - Default
Display adapter
Adapter description......... NVIDIA GeForce 6600 GT
Adapter device ID........... 0x014010DE
Display settings............ 1256x712, 32bpp
Registered user name........ htpc
Registered organization..... home
Network computer name....... HTPC
Windows build .............. 5.01.2600 Service Pack 2
Installation date .......... 30/04/2005 12:00:00
You need to try your monitor on another PC/DVI to see if the DVI DDC is missing. And try another monitor on your DVI to check if the DDC is not getting through. Either way no drivers going to work unless its getting the VESA details. I'd try a forced resolution from powerstrip.
Ok, thanks for the mnitor read out. I will definitely try to get my flatmate to help me when I next see him.
However, I will also call ViewSonic UK support tomorrow to try and sort this out ASAP.
Cheers,
Oliver
Right, just got off a call with ViewSonic support. The chap I spoke to thinks it is a problem with the graphics card. He suggested the following:
  • Obviously try the monitor on another computer, which I'll do ASAP.
  • Reduce DVI blanking, which may be the "alternate DVI mode" thing suggested previously. I can't do this at the moment but will try to when stealing my flatmates monitor.
  • Try different DVI cable
I think this whole thing rests on my flatmate and whether he has a DVI output on his computer. I don't think we have any DVI compatible PC's at work, even though we're all running LCD's.
Right, I managed to get hold of my flatmate tonight. Unfortunately his PC doesn't do DVI so I've been unable to test my monitor. I did however attach his monitor to my computer so I could run multi monitor to see if there were any difference in what I was able to manipulate in the CCC with my monitor attached over DVI. No dice here too.
I have played around a bit in Powerstrip and one have identified a couple of things that may help me if other people can try them out too. Within the "monitor information" page, at the bottom right there is a drop down menu giving options from where to read the monitor data.
I am unable to get information from the "read information direct from monitor" option and it gives me an error message saying "DDC communication with the monitor failed or is not supported". I assume that this is because I am running in analogue mode at the moment?
Is there any way that other people can try this option over both DVI and VGA and let me know the results? I think your feedback would be really helpful in understanding my problem better.
I also have tried the "Update EDID" option. I have the registered version of Powerstrip so I am able to do so. However, when I do this, I get the error message "A valied EDID was not detected on the selected monitor. Do you want to scan the bus for a EDID EEPROM?" I hit yes, and get another error message "A valid EEPROM was not found".
Is there any way that anyone else will be able to try this too?
Thanks,
Oliver
Well I tried this on my machine at work, which is a Dell Optiplex GX280 with some onboard graphics (Intel(R) 82915G/GV/910GL Express Chipset Family) connected via VGA to a Dell E173FP.
That's able to read the EDID directly from the monitor just fine so it seems that EDID is able to be transmitted over VGA. Therefore, it definitely looks like my EDID has become corrupted in some way.
I am going to try and get further help over that the Powerstrip forums and also call up ViewSonic and add this information to my support ticket.
I have been without Internet access at home for something like 5 days so sorry for the late response.
In the end the guy at the Powerstrip forum said that the EDID data that was being generated was infact wrong. I called up Viewsonic and they sent out a replacement monitor, which worked perfectly over DVI. However, it had a dead pixel right in the middle of the screen and none of the buttons on the front worked so I called Viewsonic again and they sent out another monitor, which is fine.
I don't actually have 3 monitors now; they took the faulty ones away.
