Hot water taps
Man of Honour
18 Oct 2002
Afternoon.
Doing up our flat and the hot water in the kitchen is pathetically low pressure. Tried a booster pump and we don't even get the flow rate needed to start it.
Great. :(
So been looking at instant hot water taps. But most of them that we've seen require a hot water and a cold water feed which is strange as its already heating the water so why need a hot feed?
Are there any that will provide both cold and hot water using only a cold feed?
Preferably with a small (2 litre ish) tank as it will only really be used for hand washing and washing up. Doesn't even need to do boiling water.
Power consumption below 2kw would be good to as it will be sharing an mains supply with a washing machine and I don't want it to trip anything.
All the hot water taps I've had experience with only have a cold water feed.
Also consider something like this that can be put in one of the kitchen units...
