Its time to worry about temperature again . My trusty old e6600 @3.2 is getting a bit hot . Its 27c in this room(yesterday i measured 33c and idle temps in the 50`s) and as you can see my idle temps are hot , but which monitor do i belive speed fan and real temp are 10c apart with coretemp sitting on the fence . THeses are idle temps . under orthos real temp gets into the hi 60`s within minutes and would hit the 70`s if i carried on . I`m only using 1.25 volts in bios and i have good airflow , i`m using a siverstone fortress. Oh yeh an frezer 7 pro cpu cooler aswell.
If realtemp is to be belived ,then things are too hot even in this weather
any thoughts ?????
Whats it doing in here, can a mod move please .. SORRY... DOH
