how about these spec's
31 Mar 2006
basically is this a worth wail spec, compared to what I am using now.
Gigabyte GA-N650SLI-DS4L nForce 650i SLi (Socket 775) £60 ocuk
Intel Core 2 Duo E2200 "LGA775 Conroe" 2.20GHz (800FSB) £53 ocuk
GeIL 2GB (2x1GB) PC2-6400C4 800MHz Ultra Low Latency DDR2 £28 ocuk
I don't need graphic card yet as I will save until I can get a high end card
Total £141
cheers
D
If you are planning on SLI graphics again then you will need an NVidia chipset (nForce board). If not, then most people would suggest a P35 based board such as the one Mojo linked to. They are meant to o/c a lot better.
E2200 would be a good upgrade (assuming you plan to o/c)
Edit: You can get P35 based boards which support Crossfire, but not SLI.
