Was that stock?I didn't use one and my temp under full load is 67c or less depending on ambient.
yea I get 63c after voltage mod but my chip can do -0.100 without clock stretchingWas that stock?
Current setup is..What board and cooler are you using?
That's very trueSome people wont use one cause it voids the warrenty
12700k 5.1ghz all core overclock, ecore 4.1ghz watercooled with xspc raystorm Edge Neo with washer mod sits around 65c during gaming. I'd imagine it would be somewhat slightly better with the socket mod but not installed it yet.
Oh im running way higher vcore purely cos i play star citizen and anything lower results in crashes. I'm running 1.28v vcore and 65c is pretty comfortable for me, i had similar temps before when i ran 1.24v for my overclock but it would crash on star citizen, everything else works fine though for some reason.What vcore are you running?
I'm using a Corsair 360 AIO with a 12700K at 5.1/4/4, vcore set to a permanent 1.24V and my gaming temps are around 40-50C.
65C would be way too high for me.
Ι think it's mostly aios with flat contact that need a frame. My u12a keeps my 12900k at 76c peak in CBR23 stock with no contact frame. It can also do 5.7ghz in 2 cores and 5.2ghz in all core loads (although it climbs to the low 90s in this configuration).
No all noctua coolers afaik are convex.The u12a isn't flat ? Or I missed what you meant ?
I assume you mean Thermalright?Installed a thermal right frame yesterday on my 12700kf and temps dropped from thermal throttling 100 degrees to 85. Same bios per core OC.
Highly recommend getting one!
The base of the NH-U12S is milled and left with arched grooves across the entire surface. This base is very true in flatness when a razor is placed on it with little to no deformation near the edges.
Read more: https://www.tweaktown.com/reviews/5417/noctua-nh-u12s-cpu-cooler-review/index.html
