- 19 Dec 2003
- UK
Hey folks, we are looking to help a local business out, their guy they used in the past has vanished / doesn't seem interested in their calls/business anymore and their CCTV is aging/problematic.
They already have 8-10 (let's say 10) IP Cameras in place, in a POE setup, so a single ethernet cable going to each IP Cam.
Problem is, they are a mix of different D-Link cameras (DCS-2210L / DCS-4602EV) and one of the main ones they need has stopped recording audio. We replaced it with a H.Link HV-500G2 POE cam, and it was a case of swapping it over, assigning IP to it, and it looks great! Downside? We can't record with it as It can't see the DNR-322L!
They have a D-Link DNR-322L which is awful, so what I want to do is basically, take that out, and replace it with something I can simply connect the existing POE switch to, and load all the cameras on to, and have them be able to be recording / have remote access with apps etc.
I have googled and seen Blue Iris mentioned a lot, but wondered, is that a good solution for the above? Would it be a case of getting a small desktop PC or a Synology Box (maybe a DS218J) and installing Blue Iris on it, and everything I need can be done like that?
They do not need a monitor connected to it, it can literally be a box stuck up on a shelf, as that is all they have right now. Would appreciate any advice on whether it's a good idea, does Blue Iris cover all those cameras with one license? And whether to get a Synology or a desktop PC, many thanks
