How can I delete a folder? Not as simple as you'd think..
18 Oct 2002
Around
I've just been backing up stuff to my external HDD and I've found a folder that has 'locked itself'..and I can't for the life of me unlock it/delete it.
Here's the folder info:
All of the permissions are identical to the other folders which aren't locked:
rm -rf fails as does sudo rm -Rf
I've tried 'unlocking' it via various terminal locking commands:
http://www.macosxhints.com/article.php?story=20031017061722471
Nothing works!
Anybody any ideas? Please nobody say "untick 'Locked' in Folder Info"... :p
Nothing works!
Just look for a little padlock symbol in the bottom right corner of info. Its like a smaller version of the one on system preferences in accounts.
See if it does anything, then let me know. And I will look into it more. :)
This is a FAT32 drive if that helps ;-)
macfb - can't find a padlock :(
EDIT: 404 when trying to download forcedelete too :(
Do you have a way of booting into Windows?, could be it has become read-only but because its FAT32 OSX has no way of unsetting it, on windows you would just run attrib -r filename.
A quick google shows other people with the same problem in OSX and Linux, doing it from Windows seems to be the way to go.
HTH
Yeah, I had to do the same with Windows a couple of times, a weird file that doesn't want to go from the trash appears every time I download something in Windows.
Have to use attrib -r to kill it.
If you can't get it deleted, could you make a video about it and then upload it to youtube so I can see what actually is happening with it.
Thats if you haven't sorted it. :)
P.S. I know its a strange request, but hey :)
EDIT
Oops I saw what you wrote about the uncheck locked... but why dont that work? I had thje exact same prob with FAT32 and it worked fine for me??
I have the *exact* same folder on a pen drive I can't delete. When its happened in the past I had to format it. This time I'm just ignoring it!
Because when I click it, it won't untick :p
Hmm that is strange, it definitely worked for me and I was able to delete it... It only had like 2 files in it, maybe that had something to do with it?
You shouldn't have any probs getting rid of it in Windows though
