- 13 Oct 2004
- Teesside
As the topic suggest without upgrading my wireless router (and keeping to a reasonable budget) how can i upgrade the signal that my computer receives. My brothers both get 5/5 signal and i get anywhere from 1-4/5. Im the only gamer and it's annoying me that there rooms are slightly close to the router and getting a lot better signal with identicle wireless cards.
Im hoping that you can buy perhaps extended antennas that fit to wireless cards, or hoping of some home made signal boosting methods using wire
Please suggest how i might improve my signal strength
Thanks in advance
Thanks in advance
