How do I enable Intel Quick Sync?
Man of Honour
29 Mar 2003
Stoke on Trent
I have an Intel Sandy Bridge i7 2600k, Gigabyte Z77X-D3H motherboard and I use the graphic chip built into the mobo to drive my two monitors.
I've Googled for over an hour but can't see how I enable it.
Any help appreciated.
It's automatically on as long as you're using the inbuilt GPU. All you need to worry is if the software you're using supports it.
