How do i find out what mothertboard is inside?
3 Dec 2010
Hi, A newbie question i'm sure but i have a q6600 at 2.4 and was wondering how i find out what motherboard it is on?
Thanks
Paul
Download CPU-Z and flick to the relevant tab for the info!
EDIT: Which is 'Mainboard'
You best bet is to download and run CPU-Z and see what it says in the mainboard tab.
Also, if your PC is a pre-build (from a company) then if you know the model name of the PC, you can usually find out what motherboard is used.
