How do I find out what speed my PCIE GPU is running at?
28 Aug 2006
Hexham
Have just ran 3DMark 2006, and got what appears to be a very poor result of 3023 - http://service.futuremark.com/compare?3dm06=2522171
Comparing it to a similar setup to mine here - http://service.futuremark.com/compare?3dm06=1014152 shows my AGP rate as 1x, and his as 16x, can this be right? Is there an easy way to find out through software? Thanks. :confused:
Thanks for the replies, looking for an update now, then will try other things if a BIOS update doesn't work. :)
Hurrah!!!
Card was in the wrong slot, doh, was messing round a couple of months ago, and must have swapped it over for some reason. :rolleyes:
Working now, gonna run 3DMark again, see what difference it makes, thanks for all the help. :D
