how do i fix this
9 Dec 2012
newcastle upon tyne
ok guys when i installed windows to my computer the sreen fit perfectly now after doing the windows updates there is a a black bar to the left of my screen where it does not match the sides how can i fix this ?
all i can se on picture setting on the tv is
aspect ratio
picture wizard
picture mode
pretty sure theres a setting in the igpu console or software,intel or amd where it lets you setup a custom resolution or adjust the picture to fit the screen
might have a scaling option also
im useing a intel core i5 3570k on a 37" lg tv
Really it should be somewhere in the TV settings, this is an annoying problem with VGA sometimes.
What LG TV model is it?
