- 21 Sep 2003
I've just got a Gigabyte Sniper motherboard, which has onboard sound provided via a Sound Blaster Recon 3D. There is a optical out on the back panel and I have that connected to (via a hub) to my amp. But no matter what I do, I can't get anything other than 2-channel sound. The motherboard manual just says connect either via optical or coaxial (I've tried both) and you'll get 5.1 but I tried some test videos on Youtube and...nothing.
This is, incidentally, exactly the same issue I have with the previous dedicated card I had (a Sound Blaster X-Fi Extreme Audio) - I've never been able to get it to work. I am hopefully missing something really, really stupid here, so please tell me, because this has frustrated me enormously since I originally got the X-Fi on my previous build 6 years ago!
Edit: I should add that I've tried it with the X-Fi too and that doesn't seem to work either. For the Recon3D in the sound options panel it lets me configure speakers, but no sound comes out when I do the test. For the X-Fi it would never seem to let me even see any speakers, let alone test them. I run Windows 8.1, if that makes a difference (used to be on Vista).
