I'm trying to get 2 HDDs into RAID on my Tyan S2915 mobo but the manual isn't very helpful when it comes to installing it. It only outlines that you have to make a driver diskette using the mobo driver CD and then install it when prompted to press f6.
I did that aswell as enabling RAID in the Bios but when it comes to selecting the HDD to install windows on it says "No harddrives are connected, power them on or connect them etc"
Anyone know what I'm doing wrong? Thanks
I'm using xp64 btw
I'm using xp64 btw
