NuTTiE said:OR DO START, RUN, TYPE IN MSCONFIG, GOTO BOOT TAB AND SELECT SAFE BOOT, RESTART COMPUTER AND THERE U GO.
THE NEED TO TURN IT OFF THE SAME WAY
kicks66 said:i think that doesnt work with some pcs, it definitely doesnt work on mine, ive hammered f8 on start up and its never gone into safe mode
NuTTiE said:i was just providing an alternative i know its easier to press f8, caps lock turned off![]()
Your shift key is broken now.NuTTiE said:i was just providing an alternative i know its easier to press f8, caps lock turned off![]()
