How do i go from 1.1.2 to 1.1.3 using ZiPhone?
9 Jul 2004
Nottingham
At the moment, im reading the sticky but its not making much sense.
"If your iPhone is already unlocked on a lower firmware, I strongly recommend pressing 'Restore' in iTunes so the iPhone is completely wiped and start again. You can upgrade and then do it, but it is not recommended."
As i am doing this, it is saying "backup ipod or not", so i am saying no because i dont need it backed up, and then it is saying it will restore and update it to 1.1.4, which i dont want to use (i want to use 1.1.3)
In Z-iphone, it mentions "prepare for upgrade" but do i do this instead? I've been trying to figure it out but im stuck, so please help!
Thank you. :)
Why don't you want 1.1.4, it's a lot better than 1.1.3.
But anyway, if you want 1.1.3 then download it here. Then, press and hold the Option key (Mac) or Shift (Windows) and click 'Restore' from within iTunes and select the 1.1.3 firmware you downloaded.
I thought there were the most issues with 1.1.4 regarding Customize, Summerboard and the most common applications?
I knew there were inital issues with 1.1.3 upon release, but i assumed they were no longer an issue now 1.1.4 was out, and had been fixed.
I must say, ive not followed the iphone/touch firmware scene for a few weeks now, so im not totally clued up about these things.
If 1.1.4 is just as good as 1.1.3 then i will go ahead and just use that. I dont use many unusual 3rd party apps anyway, just the main ones.
Will upgrade now. :)
Cant seem to get anthing to work on 1.1.4 :(
Summerboard installs but doesnt work when loaded up, the default profile still exists. Customize says that this version isnt supported (Customize old too). :(
Did a full restore so thought i would be ok.
Geting "Package Download Failed" for the majority of stuff.
That package download fail is something to do with the server summerboard is hosted on, also happens for bsd subsytems all the time. Try adding another source in installer and you shouldn't get that download error. I use this source if packages start playing up:
http://iappcat.com/r/4515
Then install summerboard from baldz source.
Thanks for that. All of the apps on this one work ok. :)
Still cant get Summerboard to work though. Load up a profile but nothing changes. Do i need any fixes?
Summerboard is hit and miss for me, some themes load fine, others dont. Not sure if there is a fix.
I havn't bothered with summerboard or customize myself since going to 1.1.4, the last time I installed summerboard my iphone needed a restore. I monitor what I install now :p
