How Do I Make a Mouse SMoother?
8 Jun 2013
Got a Logitech U0007, when i move it over the desk's top [ie physically, not the pointer movement on the puter desktop] it just doesn't feel slick. are there any tricks to reducing friction or whatever? seen some replacement feet/"skates" advertised for other models but nothing for the U0007 it seems.
TIA
The OCUK mats are really good if you like cloth ones.
If you are already using a mat then maybe you do need to replace the feet.
not using a mat, it's not practical for my workspace. the desktop is clean and smooth Formica-y stuff though so should have produced smooth movements, i thought.
i'll give its paws a proper wiping when i get in, see if that helps.
Same here been running a ocuk matt since I bought my logitech 502 2 years ago and the feet are still like new.
